Automatic or manual Carb, does it matter???
i know i've heard that a auto has a diaphram on both sides and the manual just has it on one side....what is the reasoning for this???? i changed over from manual to auto and was wondering if this will make a difference in anything??? thanks
hay
Need more info... Like what are you talking about???
The choke or what ....
diaphram ?? diaphram on what accel pump?? other that the vacuum advance on the dizzy those are the only two things with a diaphram??
When they say automatic or manual carb there talking about the choke.
tim
No, you can use an Automatic 1100 carb on a manual transmission car. Actually, my old mustang mechanic friend actually recommended it for manual transmission cars. You CANNOT really use a manual transmission 1100 carb on an automatic car. You don't need an extra vacuum line for the carb if you have a manual transmission. If you are on an automatic, you just use one of the vacuum ports already available (forget if you use ported or unported) for the modulator, otherwise on a manual transmission you'll only have the one hooked up to the dizzy.
Slade
i have a manual carb, and changed the car to an automatic, and i have used another vacuum port already available on the log to connect to my transmission module...thanks....just didn't know if i would run into other problems with this..thanks
Autolite 1100 carbs for automatic-tranny cars have a dashpot on the side of the fuel bowl opposite the accelerator pump. It looks and is make a lot like an extra accelerator pump, but instead of shooting fuel into the engine when the throttle is opened, it uses the fuel in it's chamber (controlled release back into the fuel bowl) to delay the throttle's closing.
All it does it delay the last little bit of throttle closing...GM started using them (a little air dashpot that mounted on the intake and contacted the throttle arm directly) when they started using ported vacuum for the distributor advance (early 70's), because the combination of the light load of the auto tranny and the sudden loss of ignition advance was causing the engines to stall and die. On a GM, if you go back to manifold vacuum, you don't need the dashpot. I've had several engines with automatic transmissions that ran just fine without the dashpot.
I have no experience with Ford 6's on this one, but I'd think you could get away without one, unless the SCV-controlled ignition timing needs it. Even then, you might be able to adjust around it by bumping the idle a tad. ???
OH, and the trans vacuum modulator needs manifold (full-time) vacuum. Hook it up to ported, and it'll downshift hard while you're braking.
