Okay, I'm still only running my center carb. I'm getting occasional (like once every 15-20 minutes) backfiring from my engine. I assume it's from the carb, because it only happens under load and sounds like it is coming from the carb.
My engine currently:
idling very smooth at 750 RPM (and I mean very smooth).
15 inHG vacuum at 750 RPM
8* BTDC initial timing.
Now, I'm thinking that my advance curve may not be working properly and maybe the engine is not advancing enough at higher speeds. I just thought about that as I was typing this. I have not checked my 2500 RPM timing.
Is there anything else I should be looking for? I want to solve this problem before I hook the offy back up.
Slade
Slade
