Greetings! I hope that a Merry Christmas was had by all!
I've got a couple of problems I'm trying to rund down on my 200 ('66 Mustang, load-o-matic dist. w/matching Autolite 1100 carb... running a Pertronix 1).
I know that I'm not getting enough vacuum (as evidenced by a split flare at the vac diaphragm and a loose hose at the carb)... but I've also got a breaker plate that, instead of snapping back when rotated, slowly meanders back into place, and sometimes needs a little push to get there. I'm not entirely clear from the shop manual as to how to get the breaker plate out for lubrication (but I think I can work my way through it).
That being said, my question is twofold:
1) what is best to use to clean the breaker plate assembly, and
2) what lubricant is best to use?
Thank you for your time, folks.
A Happy New Year to you all!
