MercuryMarc
A few years ago I put a Flamethrower coil and Pertronix unit and ran the coil terminal to the original wire, which is downstream of the ballast resistor, so I think the coil receved less than 12 volts (I think 6-9 v).
I rebuilt the motor and added a duraspark 2 dizzy + control mudule- wired it just like it says on the Joe Trojan and Mustang Steve Sites (thanks Joe and Steve). I am still using the Flamethrower coil past the ballast resistor.
I noticed on the coil (that I got in the boneyard from the 81 Merccury Zephyr 200I6) says "12 volts."
Should I bypass the ballast resistor and supply 12 v to the coil (Flamethrower or the old Autolite)? Plugs gapped at 0.050.
Thanks-
Thanks-
