I'm going to ask this question here using the air-cooled VW engine as an example, but it may apply to other makes also.
The air cooled VW is notorious for overheating, especially when todays regular unleaded fuel is used with the stock compression ratio (7.5:1). The late Gene Berg did exhaustive testing and demonstrated improved longevity by reducing compression ratios down to about 6.6:1. Gene did most of this work based on altitudes near sea level and high speed freeway driving in southern California.
What would happen if rather than lowering the compression, we put in bigger bore cylinders? Stock bore (1600cc) is 85.5mm, 88's and 90.5's are readily available (the engine cases and heads need to be machined to fit)
For part throttle cruise (stock heads, cam, and carb) the increased working are of the piston would require lower effective PSI to achieve the same force. Could this same force be accomplished by using a slightly smaller charge of air/fuel mixture at the higher compression level without risking the dreaded detonation/overheating? Or would the gains be offset by additional thermal losses? I'm not talking about crazy levels of compression, and just need to make enough power to get me and my lunchbox to work and back. Or would a set of NOS (New, Old Stock) 83mm jugs for a 1500 be better? I have access to a set of these also.
Any thoughts, comments?
Joe
Joe
