See the following. General statements, citing a David Vizard article, that was also done via the Richard Holdener on the same SuperFlow 902 Engine Dyno at 300 rpm per second SAE Gross. 5.545, 5.7 and 6.00 inch rod tests that others have done as well that show No Change in power or torque with a Rod ratio change between 1.483 and 2.00 ratio limits, using 302 to 400 cube Small Block Gen 1 Chev combinations with Fullile style heads with moderate 230 CFM head flow.
"https://www.speed-talk.com/forum/viewtopic.php?f=1&t=2066"
Elseware, others are frequently sceptical about any Rod ratio improvements giving Any performance improvements.
I'm journalling those historical links that affirm that a HP or Lb-ft improvement happens with a Rod ratio improvement within certain 1.40 to 2.4 Rod ratio ranges. Based on the evidence, I say it is a true thing. It's primarily happens when an engine is "Air flow limited", or where air pump CFM exceeds total engine combo intake air flow.
I also include links that don't prove an increase in power with a numerically higher rod ratio. This is about free talk, not eliminating desenting information or info that is contrary to a certain theory I might be trying to prove.
First "https://fordsix.com/threads/interesting-read-about-rod-length-ratio.18599/".
"https://fordsix.com/threads/crossflow-conrod-lengths.11741/"
Stan57 or "57Stan", the Super Atlantic 4AGE comparison
"https://fordsix.com/threads/250-vs-200-rev-limits.77066/"
Proofs:
1.Gene Berg (No SAE proven sources)
2. Chrysler Bible Performance verses Rod ratio test ( Not conclusive, the test was a rod to stroke ratio verses power and torque on various sizes of 4.04 bore LA small blocks from 340, 368 and to 410 Cubic inches with 3.31, 3.58 and 4.00 with the same 6.123 rod, and differing Cam Lobe Center Angles) See For A bodies Only. A fuller explaintion, I've not seen "https://www.forabodiesonly.com/mopar/threads/more-connecting-rod-length-theory-questions.190630/"
3. Ford's SAE gross tests on 200/221/250 on line sixes with no changes but stroke and Rod ratio (Not conclusive but anecdotal)
4. David Vizards A series Tests. Test A, 1293 cc A series with 5.75 verses 6.00 inch rod. 1:47.23 to 1:49.23 on
Vale the late FordSixer Ron B ( Ronbaom) who showed me this David Vizard 1994 Australian Brisbane seminar on Youtube.
Test B, 1399 or 1435 cc engine verses 1549 or 1559 cc long stroke engine. Full dyno tests including frictional resistance calculations. (First Conclusive proofs are 1 and 2).
5. Ford's move to long rods on the 4.0 liter Intech and Barra engine (anecdotal) and 5.6 liter Stoker ( anectodal).
6. Bill in Indy's 240 long rod 300 cubic in line six test ( Engine Analyser).
http://fordsix.com/forum/viewtopic.php?f=2&t=42347
Originally Posted by xctasy
Okay, I've got a really good one for you. I can't find conclusive info elseware.
With the only change being a shorter piston to compensate, take the stock 6.21" rod, and shove an 6.58" rod in it, and then compare the ideal power increase for any application. I recon 3 hp gain at 147 hp stock, perhaps 4 hp gain for any 200 hp modifed combination.
This is a rod ratio sensitivelty test, and it seams to work best when the stock rod ratio isn't very good. David Vizard, Phil Irving and most specialist engine builders have often talked about the advantages, but I've seen no scientific 'apples matches apples' comparisons aside from SAE papers.
Originally Posted by pssnmn1
ok this the figures for xctasy's 6.21 to 6.58 rod ratio question.
stock engine stock 6.21 rod
peak h.p. 147@3500 peak tq 250ft/lbs@2000
stock engine 6.58 rod
h.p. 151@3000 tq 261@2000
after rebuild stock rod
h.p. 197@4000 tq 310@2000
after rebuild 6.58 rod
h.p. 202@3500 tq 324@2000
interesting changes"
7. The need for good SAE approved info to validate a "proof" ( Anecdotal)
"https://fordsix.com/threads/sizing-exhaust-header-site.66242/"
Proofs:
