Dyno results in!
I'll be running my new engine (in sig), I think I better before it gets 110 outside. this time I have my sig, this is a baseline test before I go to mikes dyno shop for fine tuning. making sure what my AF ratio is then getting a slew of jets, I have suspects that I'm lean at higher speeds (65+) but right on at lower speeds (45-) so the dyno will consist of a few tests.
I'll only have 30 mins' on the dyno so Im making a list of things I want to try. as this is baseline for the new engine what should I be looking for?
I have a few ideas myself:
#'s (1st in 4th gear as base, and several others in 3rd with various timeings like before)
AF: @ wot = 12.5:1 and cruise ~13.5:1 (any steady speed/gear)
at what vacuum level my Power Valve opens up, looks to be 6.5 vac, but the dyno didn't do much, just jumped from 13.4 to 12.1 very quickly
Results:
Max HP: 101hp (flat line from 3760rpm-4460rpm)
Avg HP: 87hp (range is 2000-4500rpm
Max TQ: 162tq (1900-2200rpm)
Avg TQ: 144tq (1800-4500rpm)
Links to my previous motor...
Dyno1 = 67hp/116tq: pony carb, auto trans, pertronix
Dyno2 = 73hp/143tq: pony carb, t5, pertronix
Thanks guys!
Richard
Results:
Thanks guys!
Richard
