Blowby Catch-Can Plumbing ?
always with forced induction but also with HiPo engines crankcase evacuation or other means than PCV is needed for peak cylinder pressures.
* need to install 'catch-can' on 250 Maverick - typical catch can uses side entry large filter vent on top. no room at typical top of VC PCV/Vent locations for catch can and filter vent - no clearance anywhere else under hood...
currently runs two open vents on VC and large tube/vent from crankcase's mechanical fuel pump block-off plate. ignition side is busy and exhaust side heat limited.
** ? FOR CLEARANCE - CAN CATCH CAN BE LOWER THAN VC TOP PORT WITH CONNECTING HOSES ??
sorry for caps ...
FP boss vent and SC return to Oil Pan ignition side
VC - CK vents Maverick hood is lowest and 250 is tallest small block six....
thanks
sorry for caps ...
thanks
