Your gonna hate me for this, because it indicates a sea change for me!
1.I've gone off big overbores since posts from other engine builders here. I have gone to 56 thou over, and I'm not certain that its a good long term move. Lets face it, a hot six cylinder engine is an asset. The thrust faces go down to 120 thou or so with a 60 thou overbore, and about 150 thou stock. The ideal for an 11:1 comp engine is 180 thou or so.
2.My recomendation is the least amount you need to get the bores true. If you can get away with 20 or 30 thou, then do it!
3. I'm looking at sleeving now. A set of Falcon XR6 Turbo size pistons are 3.632", 1.163" tall compression height, and with a 24 thou over bore, your 3.68" bore I6 could drop a 65 thou wall thickness liner like one of these
* for small money, and I'd last the next 50 years of 20 thou over bores with each 15 years of balls out motoring!
This is an example of proprierty liners. Most Americans would never put six liners in an engine, but overseas, its done lots where good core units are harder to find.
* Shriram #2266, Dry liner, Semi finished. A 65 thou wall thickness liner which can be machined to take modern trim deck pistons!
http://www.shriramindia.com/prorange_ford.htm
eg. Pinto 2000
Capri 2000
Cortina 2000
Escorts Rs. 2000,
Taunus 2000,
Consul 2000 OHC
3.5748"
90.800mm
3.7045"
94.094mm
