Im trying to figure out what i should use for the BSFC for a 300 turbo engine. I read about it all over the net and some say 0.55 and some say 0.65. I wouldnt want to just take the average of the two becasue that leaves a 0.05 margine fro error on sioemthing that should be fairly accurate.
How can you tell what BSFC you need for an engine? Whether it is .60 or .65.
The formula: (HP x BSFC) / (#injectors x duty cycle)
You can do .55 BSFC and get 192.5 at 350 HP or .65 and get 227 at 350 HP.
The injector flow rates vary from 40 lb/hr to 47.5 lb/hr
Wouldnt there be a significant difference in whether i ran 40 or 47?
Give me some input as to what is the best way to go about doing this.
Adam
Adam
