With the final overdrive gear ratio of .78 it would be at 2400 rpm at 75 mph. I feel like that is a bit better of an improvement
spicerparts.com
300 to 350 rpm difference at 75 mph? To me that doesn’t seem like much improvement for the cost in parts and labor. If it was 800 to 1000, that might be a different story.With the final overdrive gear ratio of .78 it would be at 2400 rpm at 75 mph. I feel like that is a bit better of an improvement
I was going to change the rearend too but I don't quite know to what. Mist of the recommendations I see are for performance cars not little puttering around cars300 to 350 rpm difference at 75 mph? To me that doesn’t seem like much improvement for the cost in parts and labor. If it was 800 to 1000, that might be a different story.
This is one reason I will be going with a 8in rear axel- gear options.
Oh actually I just looked at it. Its like a 600 rpm difference. Sock its at 3100. With the final overdrive its 2419300 to 350 rpm difference at 75 mph? To me that doesn’t seem like much improvement for the cost in parts and labor. If it was 800 to 1000, that might be a different story.
What is the need for driving so dangerously fast? Slowing down will lower the rpm into a sane region, and recreate the chance of surviving a crash. ??2742 still too high?
Kinetic energy = 1/2 MV squared. The effect of increasing speed is far more energy-intensive than our human logic casually assumes.I figured. I never did actually calculate it but i figured it would be lower even if its just a little bit. Im more concerned about the rpm. We'll see if I decide to swap the rearend or go with the GV.
Doubling speed quadruples the energy stored in the vehicle. And every variable associated with it. Wind drag being the primary factor in why slower is more efficient. Engine RPM is very much of a secondary factor. More engine power is required to move faster, regardless of RPM.
There is 2X more drag at 70 mph from 50 mph.
(Just for kicks-) Taking 45 mph as a base-line, the drag increase as speed increases is:
45mph to 50 mph = 23% more inertia/wind drag
45mph to 55 mph = 49% more inertia/wind drag
45mph to 60 mph = 78% more inertia/wind drag
45mph to 65 mph = 209% more inertia/wind drag.
45mph to 70 mph = 242% more inertia/wind drag.
Stopping distance and impact inertia force go up by the same percentages. . . Slower is better in every category, including getting home undamaged and uninjured. . Regardless of how much gas is left in the tank.
