Well, it is a hardcore session of course. The same as any one elses, but distilled, hi-proof, and ever so much more so.
SR said:-
The 302 uses a 50mm T/B, the 300 a 43 or 44, I forget which. The ratios of their areas is approx. 1.3 which is the approx. ratio fo their HP and torque peaks. There's some kind of an optimum velocity thing happening there, don'tcha think?
Crictical air velocity is 200 feet per second according to Ricardo, and almost everyone else since the 30's. If the air speed is lower at wide open throttle, it will gain power at the expesne of low-speed torque. If its above 200 feet per sec, the car will gain torque in the lower regions, but loose it in the high speed zone.The Throttle bodies are not to be sized to drop the air velocity below this speed if at all posible.
However, analysis is a funny thing. An 85 250 EFI Falcon has 5.14 sq inches of area, or 0.035718 sq ft, on an engine reving to 4500 rpm. Cfm demand is about 277 cfm. Since Q=v/a, the air speed is about 129 feet per second. But remember, the throttle is a flow limiter, and it have 12 inches of torque ram affect. Its intake runner volume is about 2 liters, or 121 cubic inches, almost 50% of the total swept volume.
So I surmise if you intake runner length is long, and the volume is fairly small (<than 50%), then you can go for an air speed at maximum revs of less than 200 feet per second.
I'd suggest everyone pool there candidate engines MAF size, runner length, and maximum revs, and then see what the sweet spot is.
A 225 5.0 HO has a 50 mm throttle body, and has 0.021135sq ft of area. It revs to 5500 rpm or so. Air demand is about 408 cfm. So air speed through the throttle is about 322 feet per second.
On a 300 EFI, it lookes like about 277 feet per second for a 75% ve engine reving to 4000 rpm with a 43 mm throttle body.
On a twin throttle body 300 EFI, I'd say 173 cfm for a hot I6 reving to 5000 rpm lookes just fine.
The 4.0 V6's have some funny throttle bodies that don't flow well, as I stated earlier. There is a 'gate valve' co-efficient due to the smoothness or otherwise of the throttle body. I've seen road car HSV Holdens that use one 80 mm throttle bodies, and only reving to 5500 rpm. But on race cars, and auxilary 80 mm throttle body allows the engine to rev to 7500 rpm! 660 cfm deamand on a 100% VE EFI engine, with 450 hp, and 100 feet per minute at max revs. It did have a Calpak Delco, and DFV/DFX-style injector trumpets like the latest 5.4 DOHC Mustang Mach 1 engine.
See, doubling up lookes like a neat idea.
