8) if you are using the stock log head, even in modified form, a dual pattern cam will be best for overall performance and economy. it will actually work best right in the range where you need it most as a daily driver. if you are going to use the 250 2v head, either of the argentine heads, the crossflow head, of mikes new aluminum head, then go with the single pattern cam, especially if you are modifying the above listed heads, for best overall performance. single pattern cams are best when the intake and exhaust flow is properly balanced, like you would find in the new aluminum head. a dual pattern cam is best when the flows are way out of balance like you find in the log head.
