All Small Six Cam Recommendations
Falconfree
I am looking for cam advice.
I have a 200 that I am rebuilding to place into a 63 Falcon. It will have a 9.5:1 compression, a large log head that has been modified for a Carter BBD. Headers and a DS2 round out the build. It will be bolted to a 5 speed trans. I am looking for a bit more spunk when I nail the go pedal. I'm not looking for a race motor as I will be driving this quite a bit so good idle and drivability is a must.
Schneider cams recommended their 280H.
My question then- Has anyone else used this cam? What was your experience? Is it doing about what you expected?
If not a Schneider cam, is there another cam that you have experience with?
The whole cam thing has me befuzzeled and any advice would be appreciated.
Thanks in advance.
Terence
Hi, what year is your engine? Early engines, maybe all engines with 3 freeze out plugs, do not have an oil supply for hydraulic cams. Good luck
