Carb Spacer
You might it all depends on the throttle linkage you have or if you want to convert to a cable type linkage. :nod:
I don't use one. I think it may only be necessary for only certain climates.
I use a spacer without the heater line just because it has a vacuum line. I need two vacuums sources one off the carb for the vacuum advance and the one off the spacer is for my vacuum windshield wipers. I also do not drive my car in the winter so the warmth for the intake doesn't matter to me either.
where did you get your spacer?
I have two without the heater hose lines. The one I am using came off a 1973 Maverick 250cid. The other one I believe is off a 67 200cid can't remember for sure. What size throat do you need? The one I have is 1.375". It maybe too small. Can make you a deal if you want it.
