Carter RBS Carburetor gasket
Mr Comet
There is a rubber gasket which fits into a track on the main housing of the RBS carb. where the bowl is attached. Two questions I have are, is there some kind of form a gasket which can be used their? I still have the rubber gasket but it is a little small right now. Is there any trick I can use to get the gasket a bit larger? I tried stretching it but that has not worked so far. Any advice. Thanks
You could try soaking it in some hot water to soften it up.
