My Duraspark II is in and running nicely... now I need to focus on my carb issues. Currently, I'm running a Holley 1940 that appears to be in dire need of a rebuild. Here are the options I'm considering:
1) Holley 5200 from Stovebolt (pro - great carb, well respected rebuilder/seller. con - carb orientation, must fab linkage, must fab aircleaner, hood clearance issues).
2) Carter RBS (1-3/4 inch throttle bore. pro - direct bolt on, "set and forget" carb. con - rebuilt, may have to fab throtte linkage).
3) rebuild my 1940 (is it even worth the effort?).
Cost between 1 & 2 is about the same, assuming I don't have to convert to a cable throttle link. for the RBS. 3 is cheap... but I'm not overly impressed with what I've read about 1940's here on the forum.
Any and all advice is appreciated.
