Anyone have any experience running ceramic coated pistons? I talked with an engine shop in LA last week (they ordered a few parts) and he said he uses coated pistons all the time.
Here's the reasoning: Coating pistons tops with a ceramic coating protects the piston in two ways. First, the ceramic compound has a higher melting point than aluminum. Secondly, it conducts less heat (insulates). A silver coating, like Jet-Hot Steerling, reflects heat away from the piston. This helps keep heat in the combustion chamber, which makes more power. Other advantages are lowering the temperature of the piston, and reducing carbon build up on the piston.
According to him, an small inline six can run a 10.5 CR on pump gas with no additives. He claims its an ideal step between cast and forged pistons.
I have also read about coating the piston skirts, inside of the combustion chambers, and the exhaust ports in a tech article.
Anyway, if you guys like the idea, I will bring in some stock pistons (flat and dished), have them coated, and keep them as a stock item. Just looking for some feedback?
The most common applications for ceramic coatings are on the exhaust system, manifolds, and headers. When ceramic thermal barrier coatings are applied to exhaust manifolds or headers, they provide two advantages. They protect the headers from rust and corrosion and also reduce heat loss, which translates into high power output. If the headers are internally coated, they will create a higher velocity of the hot exhaust gases and less turbulence due to a smoother surface.
Pistons can also increase their performance characteristics with ceramic coatings. Coating the piston's top will cause heat reflectivity, driving a percentage of any detonation energy back into the fuel burn zone, to increase fuel burn efficiency. It will also lower carbon buildup, which reduces detonation quality. By protecting the piston surfaces, it will allow for a leaner fuel mixture.
Piston skirts can be coated to create an excellent dry sliding surface during engine start-up and will help eliminate skirt slap during initial engine run-in. Using a dry coating will fight against scuffing and abrasion of the piston skirt during its stroke travel inside the engine block cylinder. The inside of the piston can also be coated with an oil-shedding coating to cut parasitic drag and return oil to the sump faster. Ceramic coatings can also be applied over the piston ring contact face of OEM hard chromium, which provides lowering friction between the ring face and cylinder inner bore surface scuffing, and also improves wear resistance.
Ceramic-coating the cylinder head's combustion chamber and exhaust ports will create a faster, hotter burn and help scavenge gases at a faster rate. The coating of these passages also creates thermal transfer from hot gases to the heads themselves.
