cameljockey
this is probably a premature question but seein as how I'm usin 2.5 L HSC rods with stock pistons in my 250 ci build i was wondering what the chamber volume on the new FSPP head will be
I'm tryin to get a handle on my compression ratio. If you don't want to divulge those numbers just yet I understand but please tell me if it will be too high for a street motor using TBC's and SDF's where ever possible. I mean to coat the valves(stems and faces), exhaust runners, bearings (rod and main), pistons, and crank shaft.
deck height: 0.024 in
comp gasket: 0.037 in
stroke: 3.955 in
bore: 3.680in
Thanks and Keep Sixn'
Dan Hanna
stroke: 3.955 in
bore: 3.680in
Dan Hanna
