Ok, 3 months later and I finally have repaired (http://www.Robaldo.com/ProjectLazzarus) enough of the accident damage (http://www.Robaldo.com/CarWreck) on my son's 66 coupe to get the CI head install back on track.
So now I'm posting some photo's of the install. And hopefully some of you can give me a hand with some ideas for any problems I run into.
The block as it was right after pulling the cast iron head off, All that water in Cyl 6 came out of the block when we pulled the head.
Here we've cleaned up the block & installed studs:
Next we put the head gasket in place, being sure that it's not upside down:
Now it's time to bolt on the head:
Then the intake, it took a substantial bit of precussion engineering to get the necessary clearance:
Finally, we come to the carb. I'm open to suggestions on this one. Which way should I face the carb, & ANY ideas to hook up the throttle linkage would be welcome.
Thanks,
Lance Robaldo.
Thanks,
Lance Robaldo.
