How well would a Clay Smith H64/74 10 dual pattern cam work in a 170 bored .040, decked to zero, 250 head milled for 8.9 compression, 2 barrel carb with bolt on adaptor from Stovebolt. 3 speed standard with a 3.something rearend. the cam has the following specs.
Intake duration at .050 is 214 and intake valve lift is .480. Exhaust duration at .050 is 224 and exhasut lift is .480. Would this work okay in my engine? thanks
