Clifford 272H cam in a turbo application?
Anlushac11
1K+
Couple of months back I bought a used Clifford 272dur and .450" lift from Mustang Geezer.
Anyone know how this would work on a turbo application? I cant find the cam specs on Cliffords site anymore so I do not know what the lobe centers are.
I also have MG's ported and polished 66ish log head with port divider.
Any help appreciated and thanks in advance.
I couldn't find any LCA or overlap data either. Jack didn't feel the need to publish it and Larry can't spell LCA.
My best guess is that it's too big a cam for a turbo app. High duration cams typically allow way too much blow thru and reduce the turbo's ability to build pressure. Look as Isky's turbo-specific cams for comparison. See pages 126 and 130 http://www.iskycams.com/onlinecatalog.html
They feature somewhat less intake lift, substantially less exhaust lift, low intake duration, essentially stock exhaust duration and a very wide LCA. They're designed for low boost pressures; larger pressures would probably require a bit more cam but it's unlikely they would require a lot more. You can obviously turbocharge with a hotter cam, but the farther from those sorts of figures, the fewer gains you're likely to see.
You can set the cam up in a block with a degree wheel and a dial indicator and get all the info you need.
A cam needs to be matched with head flow.
A too large cam in a too small head (or vice-versa) won't perform as well as a better matched cam/head.
214° on a 110° has a lot of overlap. Doesn't that conflict with the turbo's ability to build boost? I should think that something on the order of 206-208° on a 112-114° would be much more suitable.
It depends a lot on the head flow characteristics. There are some guys making crazy power with cams that most people would think have no business being in a turbo engine. If you got it for a good price it might be worth it to just try it and see. The engine will make boost regardless.
I'm with Linc's on this.
The cam in Kelly's Falcon is the FSPP 274S which is 224 degrees @ .050 with a 110 lobe center.
It seems to work pretty good I think! :D
The cam we put in Mike's EFI'd, turbo'd, '69 Sportroof is a 292 with .528" lift and 112 lobe center. Of course we haven't started it yet so I can't really comment on how it runs.
Later,
Will
I know the 2.3L ohc guys have a pretty poor flowing head (albeit better than ours) and they will run as high as a 112 or 114 overlap. don't forget though that increasing the rocker ratio will increase this as most cam specs are given for stock rockers.
That cannot be an overlap number; most likely you are looking at the lobe centers.
Typical overlaps for 300 camshafts (the only data i have real handy, 200-250 cams should be similar):
Isky turbo cam: (262-250°/208-194°/114°) = 28° overlap
Isky 256 (256°/206°/112°) = 32° overlap
Isky 280 (280°/224°/109°) = 62° overlap
