Confused on DSII upgrade
mugsy
OK, I've read the text and the responses to the DS II upgrade in the sticky :bang: . In the picture, which spring is the that should be replaced and which tab is bent? If you answer please use left/right with regards to the picture. When the description is the "bigger" spring, I think it's the spring with the thicker diameter wire, not the spring with a larger overall diameter. Wouldn't the spring with the thicker wire have a higher spring rate? And which spring is the secondary? It's all very confusing to me.... :?
tanx,
Mugsy
