kirkallen143
Anyone know of a grommet that can convert your twist-in oil breather cap to a push-in style? I am trying to install a K&N styled filtered breather to help with crankcase pressure and are keeping the pcv valve.
I have a Mr. Gasket twist-in breather now, but I don't think it is relieving enough pressure when the turbo boost kicks in (dipstick keeps blowing out). I do have a pcv for a turbocoupe and an inline check valve before that installed. Maybe it is blow-by from the rings not setting correctly, a leakdown test would show that, correct? Gosh I hope not!
Isn't there an old way to help re-seal the rings? Using Bon-Ami or something? Would it work, or not worth the time to do it now?
Thanks for any insight.
Kirk
ps. I did find that the opening underneath in the twist-in breather cap was just barely cracked open, maybe an 1/8" or so. I opened it all the way, but have not tested.
Kirk
