Valve cover/breather cap
ssg66stang
I am sorry if this is a silly question but I'm hoping someone here can give me a hand. All the breather caps that I have been able to find are either the type that twist/screw in or the type that push in when your valve cover has a rubber grommet. I came across the valve cover in the attached picture and it has a raise filler neck. What type of breather cap should I use or what modification can be made to the valve cover so I can use one of the breather caps I mentioned above?
Thanks!
Aaron
Hi,. Mustangs unlimited has a breather for 65-66 6 cylinder. #56766a for black, 56766b for chrome. Good luck
ssg66stang":25gduqb1 said:
Would this be a good option? https://www.cj
Y not ck in w/Matt @ VI. He has a frnt cap that'll allow U to keep a "closed PCV system" (iie run that 1 to the a/c) so U keep the PCValve itself on the back 1 running to the carb/intake. That way U can still have easy access to ur v/c when it's time to top off w/crankcase oil.
It looks like the 1 in B Ron's but has a lill hose barb to run the piping to the a/c. This way U support the only ford i6 exclusive motor prts dealer I know, one of our members'n a fella who stands in for Mike W the founder of this site who passed away (was it) last year. Saves $ over "CJ" too!
Win-win-win !!!
:thumbup:
https://www.vintageinlines.com/product- ... essory-kit
