What sort of manual gearbox would most likely be found in an english 2.0 litre mk3 cortina coup?
4 or 5 speed? And whats it like? What can it handle power wise? Does it respond well to strengthening? Any idea on the ratios?
And the 2.0 litre. Is it the same one found in escorts and cortinas over here? What sort of power does it make stock? What sort of carb set up has it got. How much does it weigh? Any other info?
Will the cosworth-sierra dohc twin cam turbo head bolt straight on?
And with regard to the diff. Is it safe to assume it would be the type B Salisbury unit running either 3.45:1 or 3.75:1 (as xtaxi noted in other diff thread).
What would these mk3 coupes be like to drive stock? How would they compare to driving my precrossflow 250 3 speed auto, 2.77 diff tc cortina? Similar or would they be slugs (well moreso than my tc is now) or would they be better?
How would fuel economy compare?
Thanks for the info as I am really quite very extremely interested in these cars.
