Cortina Wheels
73GreenMachine
Can anyone enlighten me about finding some decent mags for the old Cortina?
From what I know they are a 108mm PCD and i think the offset is +35 but i could be very wrong there.
Does anyone know of any other cars I can get rims off(I think there are saabs that work) and are there actually and good looking secondhand mags that will fit?Anything 14" or bigger is fine.Thanks,
73GreenMachine.
Go the Superlite 15s. Good wheel, good tyre choices. They'll drill to your specs.
i have had cortinas for over 10 years and have had around 25 of them.to me the biggest problem with them is getting large rubber inside the gaurds without rubbing the inside or chewing the outside up.i have 15" saab alloys on mine and they fit pretty good but only have 205 x 50 on them.i have seen a few with the focus wheels and from what im told the fit pretty good but to watch the offset on the front brake line but if this was a problem it could be fixed with a 1/2" wheel spacer id say.the focus 17's look hot,another thing i noticed is i looked at the new update focus to be stunned when i saw 5 stud so it looks like they may even be 5 stud now but there should be plenty of the 4 stud 1's around.go the 17's with the large spokes they look hot.
I got a set of wheels 14X7 bolt straight on but youll need your guards lipped. Theyre a Centreline copy and pretty tidy and straight. Got new speedy capsd and nuts lock nuts etc with em too. Steve
My experience has been pretty tragic. The great set of Aussie Perfornance 14 x 6 jj alloy rims are designed for much longer aftermarket studs and use modern spigot located wheel nuts like used on steel wheels. In New Zealand, most guys use washers and the old shouldered shank wheel nuts. This results in an unsafe wheel because the treads don't engage fully. Even when the sharp edge spigot nuts are used, there is very little thread in contact with the nut, way less than what Ford intended for a four stud wheel in a 6 cylinder 1.2 ton car.
Most newer 108 mm PCD Aussie mags seem to be made to Australian Standard AS 1338 for Escorts and Saabs. The nuts have to come with a more stable sharp edge which 'knife edges' up to the alloy rim. Problem is that these later AS 1338 alloy wheels then have insufficient thread with the stock Cortina wheel studs. They are way to short for safety.
The AS 1338 alloy wheels are much thicker than the stock steel wheels. I had only 6 mm of actively engaged thread. The old factory 13 x 5.5 1977-1980 TE Volante and 14 x 5.5 1981-1983 TF Ghia and S-Pak mag wheels were made with a more common shanked nut, so be carefull when you bolt on newer mags, as you may have to order a set of 16 new studs.
The biggest endorsed tyre (ADR approved) for Cortinas was the 185/70 SR 14's found standard on the 4.1 Ghia and 3.3 S-Pak in the last TF's.
As Sonny said, larger 'mags' require hammer work on the inner lip of the wheelarch. It looks savage, but a quick jack -up of the car, and a bull nose hammer, and you've rolled the spot welded wheel arch back. A sand and palm full of filler, and a prime and paint, and its done in an afternoon.
I ruined one 205/60 tyre on the passengers side front when the stock guard hit it. All it took was the first bump home from orignal owner Mikes house. After that, I ditched the stock 185/70 13 tyres on 13 by 5.5 rims. I reworked the arches, and then got a local Machanical engineering firm to source some proper longer wheel studs. No driving for the last three months as I've been doing some other mods while waiting for the bits to arrive.
the biggest tyres i have fit on a cortina are 225 brigstone egears on 13"ghia/14"spack rims.they didn't rub scrub on anything and handled great but there only a 5.5" rim.if you could take 1 into a tyre shop and get a 15" mag made to these offse to me it would be perfect.good luck trying to fit anything bigger and let me know how it goes because i would like to know as i would go for anything better.i would love a set of 15" minilites in the cortina offset,that would be great for me :)
Nice, so by the sound of things its an inherent problem to get decent mags for the Cortina. That does suck a bit.... Unless there are some good european wreckers in South Australia I might be staying with 13s for a while. Does anyone know if you can get 205 13 inch rubber without paying $140 a tyre? The whole aim of this was to put on a nice looking wheel where tyres werent too expensive. Has anyone looked into the feasibility of a 5 stud conversion does it solve any problems?
Thanks,
73GreenMachine.
If you switch to Ford 5-stud pattern there are squillions of choices. Dearer initially, but will pay for itself in wheel and tyre prices.
there are plenty of choices for 5 stud but this doesn't make the wheel whells any bigger,there not real big on a cortina,i think this is where the problem lies.
you can convert the front to 5-stud using ford trailer hubs and XF rear discs giving you 11"1/4 discs and a choice of XF, HZ, AU or AUII(twin piston) calipers using fabricated brackets. For the rear simply get the axles redrilled. I'm not saying it's the best way, but it's cheap, easy and allows you to use 16" AU offset wheels without flaring the guards
hey.
i run 15" commodore pursuit rims on my TE Cortina
they have the centers cut out anda 4 stud plate welded in place.. 6" on front 7" on rear
6.0J I SOX15 22 8 161 43P
6.0J I SOX15 22 3 32 43P
7.00 JX15 22 1 93 43P
7.00 JX15 22 1 286 43P
has 215's on them at the moment. but 235's will be on them soon. as 215's == bad on traction on take off :S
hopeing to get some 16" rims to replace them..
the new Holden VZ One Tonner Cross 6 comes with 16" x 7" pursuit rims.
just gotta source some..
I got 235's on the backof mine.they fit easy but i do have 5 stud all round with Au rims. I have also had 26x8.5x15 slicks on the back but had to bash the inner guard a bit. Nearly every manufacturer, except GM and their derivatives, use a 5 x 114.3 pcd somewhere in the model range so if you go the 5 stud there is a miriad of choices. With the 4 stud you'll fine that a lot of euro makes have rims with the same pcd as cortina, ie saab,alfa.
Here is a fitment guide that may help.
http://www.yhi.co.nz/fitment/2006fits.html
Great advice. Wheel spacers are technically illegal in all states for vehicles made from 1972 to date, because they invalidate the original ADR's for brakes and possibly track and tyre placard size. However, if the spacer is on a 200 to 1500 kilo trailer, your okay. Duh?
:wink: As a note, I got 16 new studs and new locknuts this week. 281 Kiwi bucks for locknuts you can only take off with an abrasive disc, and each one needing a :twisted: unique key lock to open.
There was no way the Performance wheels would have the thread area with the TE Cortina, so budget on extra money for safety's sake when using these really reasonably priced mags. I suspect rather a lot of Cortinas, Alfas and Saabs have a similar issues.
My wife is putting my old 'nuts' on TradeMe. :!:
