PSIG
Wanted: crank snout dimensions and balance factors for big and small sixes. Also stock damper outside diameters.
I need some input to begin a quest, for simplest OEM replacement of dampers/harmonic balancers with versions equipped with toothed wheels for greater EFI conversion and upgrade options. Simple gets it, and the ability to swap OEM dampers (or just the trigger wheel) could be a simpler option to custom wheels and damper mods. Issues with belt drives, etc, are secondary at this point. One step at-a-time.
I have searched and reviewed existing threads on this, without specific answers so far. I did find reference a few times that SBF dampers will "fit" big six without specifics. Nothing on small six so far that I've found. Any help appreciated on any six versions.
Example Ford Explorer V8 damper with trigger wheel:
Example of a stock Ford 4.6L trigger wheel:
Thanks!
