Good afternoon, I am new to this forum and use it as a reference for working on my 200 that I have put into my 61 falcon. One of the rods started knocking on the motor so I pulled it apart and found out that the torque converter was not seat fully in the trans so it had put too much forward pressure on my crank and wore out my thrust bearing and a couple rod bearings.
I have attached a photo and would like some advice. I have rebuilt some chevy and Ford small blocks but never a small inline Ford. I am not sure if the crank should have the bevel in it where the thrust bearing goes or not? I figured it should be a flat surface like a sbf. I am hoping I do not have to replace the crank.
Thanks in advance for any help!
