that is my next project to do , make a under plate that wil fit the big and small log head , and make a adapter plate for adapting multiple carbs and make a conisch form between it , so you got 2 adapter plates and a conisch form , to only thing you have to do is weld the plate,s on the conisch vorm any posision you want , and with any bolt pattern you want , i,m just into it , it wil be verry cheap parts , but firts to finish my T9 project ,
btw AL question , i got an idee for attaching a cable clutch to a bell house , will fit all the belhouses with the linkage clutch setup , no drilling only bolton , with a bracket to attacht the clutch pedal , no drilling just a bolt on cable kit !!! i will work this out in a draw and will send it too ye , look into it and give me some thoughts , ok ? btw also did make for my clutch fork a bracket with poly urethane bushing , so no more ratteling from the clutch fork , just drill the old 1 out with the stupid spring on it that hold the cluch fork and bolt this bracket in ,securesd with a hardend steel pin here is a proto type [ test ]
btw dont mind the welding ,it whas only a test for right hight and lengte !
