Agreed, but Tbone wants to do his own thing which can provide a lot of new information one way or the other. I like it.
If the block deck height is still going to be 10.00" then a 7.0" rod length is about the limit and still have good room for piston rings.
Here is one of my 300 pistons on a 6.8" rod.
Notice the piston pin is up into the oil rings so you have to use a bridge ring on the bottom of the oil ring pack.
The groove between the first and second ring is an accumulator groove.
This groove machined in the 2nd ring land adds to the volume between the top and second ring.
This groove accumulates residual gasses from combustion which alleviates top ring flutter and premature second ring wear, improving ring seal.
Part of the ring spacing depends on the material you will be using in the piston.
If it is brittle, then you want a wider spacing to prevent broken ring lands.
If you are looking for fuel economy use a thin metric ring that has less piston drag and better cylinder seal.
The thinner metric ring pack is more compact and can stay away from the piston pin bore.
Do not gas port a street driven piston. The ring wear is substantially increased.
A flat top piston offers better flame propagation over a dome piston.
Besides that, a flat top piston gives you an 11:1 compression ratio with the standard pre- 1987 300 six.
You will probably need a piston dish.
If that is the case, the inverted dome piston which mirrors the combustion chamber offers the best combustion efficiency.
