The Drop A Load is easy to do if you wanted to keep using the Autolite 1100 that you have. Yes using a Holley 350 or 500 2V Carb would be a good way to go and also solves a few of those problems. There is also the Carter BBD 2V Carb that some having been using now that's also easy to mount to the Large Log Heads see below link. Are you going to change out the camshaft soon?
Carter BBD 2 barrel on a 200 large log six
I replaced the low top BBD with the newer model high top BBD. I changed the choke shaft from the low top to the high top so my manual choke linkage would work. The ported vacuum works the way I want it to on the high top (no vacuum at idle). There was always some vacuum at idle on the low top...
vb.foureyedpride.com
