Dash swap
Hi guys,
Do the elec. dash's in the fairmont and s pack swap with basic gl dash wiring without any probs?
Cheers
FalconHell
_____________________________________________________________
Big engine and gearbox replacement this sunday in the mighty XF
The Fairmont dash will drop into the XF dash.
But the oil pressure switch will have to be changed from a light unit to one that will operate the oil gauge correctly
Noel
Thanks Noel, How about the tacho on the fairmont dash, is that already wired into the dash loom in the gl's?
Yes, they go straight in and everything works once you change the oil pressure sender to the correct type.
