chopperman69
I've got a long term 200 project that is finally getting close and I'm a little stumped on degreeing the cam. Here are the specs.
200 (+0.030)
Clay Smith/Classic Inlines 264-110 cam
JP Performance dual roller timing chain
I've got the timing set installed dot-to-dot, the crank key and the crank gear slot (0) are at 12 o'clock, and the dot on the cam gear is at 6 o'clock.
I determined TDC using a piston stop and a degree wheel so I'm certain this is correct. When I degree the cam on the 1st intake lobe, I'm seeing about 3 degrees at 0.050 BTDC. When I look at the specs posted for the cam, it shows it should be 22 degrees.
http://classicinlines.com/proddetail.asp?prod=CSC-264-HSP-10
I didn't expect it to be perfect, but I'm alarmed it is off by a mile. I check this several times and I keep coming up with the same results.
My ultimate goal is to advance this cam 4 degrees, but I'm not sure how to get there from here.
Any suggestions?
Scot in OKC
200 (+0.030)
Any suggestions?
Scot in OKC
