Well, my Clifford adapter came today and I excitedly did a test fit with the Demon carb on my manifold (original adapter removed). The little extension at the top of the carb has about 0 clearance to my hood (didn't have any playdough, but did have some 1/2" foam, which it compressed when I carefully closed the hood. Granted, I haven't yet filed away the adapter to clear the throttle mechanism, but that will probably only give me 1/8" max. Since I didn't have gaskets installed, the 1/8" I gained will probably be taken up by around half or so. So bottom line, there's no way the 2.18" high, 14" diameter air cleaner I ordered will work.
So now I've got some options to consider:
1) Have adapter milled (looks like the MAX I could gain is 0.25", maybe less than that), hoping that I can find an ultra low profile cleaner.
2) Go ahead and bolt everything together to see how it runs, and order a hood scoop/or hood with scoop when I can.
Anything I'm not considering, that I should?
(BTW, I'm not thrilled that I have to figure out how to offset the throttle linkage 90 degrees, but at least I've seen others do that and can get some ideas from photos I've seen here.)
Thanks so much for any help/advice!!!!
James
James
