DGES Linkage
Ronbo
Ok, I currently have a DGEV with a Lokar cable set up. Carb is toast, completely, so I buy a DGES (mayyyybe a bit too big) and need to hook up a linkage. I am about to fab up an arm for the throttle shaft because it has a funky looking "U" shaped deal on there. Before I do this, has anyone purchased a linkage kit that worked with the DGES? Really dont want to go through the pain if I dont have to. Thanks!
Ron
can't you just use the linkage from the toast and transfer it to the new one? By the way, want to sell the toast ?
The toasted carb is a HW5200. You'd be better off buying a rebuilt from stovebolt because the throttle shaft is worn on this one. The throttle arm will fit on the DGES but its aimed in the wrong direction. I think Pierce manifolds may have the fix for me.
