Yes I'm still off in the head. What would cause this condition?
Am I off the hook it it's genetic?
wsa111":33fybdhc said:Don, you might want to angle mill the carburetor adapter at an angle so the carburetor sits level.
Also where are you hooking the pcv valve hose. If you have a late model head change the pcv to the vacuum source at the back of the carburetor.
Also you can jet the carburetor say to a 59 jet at the front of the carb & leave the 58 at the back. This will give you a consistant fuel mixture to all cylinders.It is very common to stagger jet the carb to compensate for this condition.
http://fordsix.com/forum/viewtopic.php? ... 270aeeec2b
Look at my setup with the adapter angle milled. Hope this helps. William :idea:
