I'm looking for a supply of some 2305 carbs.
Anyone here know about or have the later staged 2-bbl Holley carbs? They use the stock 2-bbl Holley 350 and 500 cfm casting with a special Weber style mechanical secondary baseplate. The throttle linkage is not in the normal spot, its behind the back.
They were often used as a replacement for some Holley Weber 5200/5210/6200/6500/6510/6520 and Weber DG series carbs like the DGAV32/36 and DGAS38.
They were a flash in the pan, something that TBI and CFI, and lack of any OEM use, put paid to. After Ford Australia pulled out of the Turbo Falcon project in 1984, Australian Ford Mustang and Falcon racer Dick Johnston used one on the Aussie XF 1987 SVO Falcon project in his development ute and made good power with 196 hp using it, but it never caught on.
Plenty of cross flows, slant sixes, and 235 Chevy engines by Tom at Stovebolt used it, and Slant guys like Reed Speir and Chevy in line nuts like the 12 Port Advisor, tlowe #1716 on inliners international and at Autowerks have done 2300 to 2305 conversions since it just uses Mechanical secondary Holley 4-bbl parts. It has a unique metering block, but is bascially a 4150 4-bbl cut length wise.The fuel bowl and metering plate is mounted on the side of the carb not the front like the 2300. One jet feeds the primary and the other feeds the secondary.
http://www.inliners.org/ubbthreads/ubbt ... 5ee777a963
http://www.slantsix.org/forum/viewtopic ... bd708cbe94
