I66coupe
Everything!
What determines what the curve should be in the distributor? How do I determine what the curve should do? There's a thread here about curving and its suggested to send the distributor to a fellow and let him do it for you. How is it determined what the curve should be? How can he decide how to adjust or modify the unit to suit your particular engine? Are there some basic guidelines we could use?
I am planning to install a 1980 DuraSpark in my '66 engine. I would believe that the curve will need adjustment due to the differences between a smogged 1980 engine in a Granada and my non-smogged 1966 Mustang engine. How do I decide what it should do? How far should it go? How fast should it get there?
I read here that the 1100 spark control will pull the advance too far and pinging is likely. So, what is the problem with the vacuum signal from the 1100? Is it that the vacuum is too strong too soon? Does it slam the advance full on way too soon? Effectively bypassing the weights? They essentially do nothing due to the strong vacuum signal slamming the advance full on? Is it that the SCV applies too much vacuum at higher rpms and thus advances the timing too much? If that is so, can't I simply limit the advance travel with a screw installed in the distributor to interfere with the advanve arm's travel? I gather that I will need to replace the 1100 with something else because of this problem. Thats ok, I have a 2100 on the shelf. Couldn't the SCV problem be addressed by using a later carb? Is that what I should do? Replace my '66 1100 with a '68 or later 1100?
I read that I can open up the gap on my plugs to take advantage of the higher energy spark. I uderstand that. I upgraded the ignition on my '83 Jeep J20 by using the Ford TFI system. The Jeep engines came equipped with the DuraSpark ignition but used the old, lower powered canister style coil. I opened up the plug gap to the amount suggested by the Jeep crowd and the upgrade worked wonders for the old Jeep. How do I determine how far the open the gap for my '66 200? How do I decide when I have opened them up too far? Not far enough? What clues do I look for to tell me this?
In the DuraSpark conversion for the '66 engine, its mentioned that it will supply more energy. How? Is the DuraSpark coil more powerful? How does its output compare to the TFI coil? After seeing what the TFI coil did for my Jeep 360. I would think using the potent TFI coil with the 200 would also be a great idea. But, I only see the canister style coil mentioned for use with the DuraSpark conversion on the 200. In the TFI conversion for the Jeep engines, its mentioned that the TFI coil has faster rise and fall times for more precise timing. Wouldn't this benefit our engines as well? This is pointed to as a big plus for the TFI coil over the canister style.
Also, in the article about the DuraSpark conversion, its mentioned that the white wire retards the timing for less load on the starter. The Jeep system uses this feature and it works great. But the article points out that the Mustang wiring can't accomplish this with its stock wiring configuration. Well, just use a relay controlled by the start terminal. When the start terminal is energized, the relay will pull in and supply power to the white wire independant of the stock wiring system. When the start terminal goes dead when the key is released, the relay drops out and power is cut to the retard wire to the DuraSpark module. This is not mentioned in the article.
I have questions, do you have answers?
