Distributor points screws
:D If you need screws to hold your points assembly. Dorman Products has them. I found a container in alittle hole in the wall auto parts store in Sebastian FL. Hell, it made my day...ZZ :wink:
Do the screws you found have the binder heads? Binder heads have a small ridge around the perimeter of the lower surface of the head. I noticed the stock ones have the binder head. The box of binder head screws I have, have a slightly larger head than the stock ones but still fit.
Steve
:D :D :) :) :o :shock: :lol: :wink: :o :( :) :D Well., the screw design is shorter than the normal ACE H ardware store. The head is larger . It do0esn't come with a ridged bottom, but it has a lock washer. IOf ya need them let me know..
Dino
