Hi all.. I'm new to this board even though I've been around the Stangnet boards for a while..
I've got a '66 200 Mustang that runs extremely rough. I'm thinking that the distributor might not be installed correctly. Here's my questions:
1. If the #1 cylinder is exactly at TDC, where should the rotor point? Perpendicular to the engine and towards the left side of the car?
2. How loose should the rotor be on the distributor shaft? Mine can wobble up to about an eighth of an inch. I thought they were supposed to fit on fairly snugly.
3. Can somebody explain to me how the distributor can be a "tooth off"? I understand that the rotor will not be pointing in the correct direction, but can't this be fixed by rotating the distributor body to match it (aside from the inability to connect the vacuum line)?
Thanks for your help, guys.. 8)
