Hi all,
I've been fiddling around with the timing on my `62 (with a `68 200ci and Ford-o-matic) and came across a page talking about adjusting the advance curves on your distributor http://www.bob2000.com/dist.htm
Out of curiosity, I pulled the plate out of the distributor to look at the springs and noticed that one was considerably beefier than the other. I took a photo that can be seen at http://home.comcast.net/~purlgurls/distsprings.jpg
Are these springs supposed to be the same size or are there many different combinations depending on the advance curves you're looking for. I've never dealt with this type of "fine tuning" so it's all new to me. Maybe it's something I shouldn't worry about or mess with? Also, I notice the numbers stamped above the slots on mine are "13R" and "15R" while the web page I mentioned has them marked with an "L." Anyone know the difference? And...there is a rubber sleeve over the limit pin on mine and that's not mentioned on the web page. Is this stock or someone's attempt to change the 13 to a 12?
Also, I have a video that came with my Autolite 1100 when I had it rebuilt at Pony Carbs and they mention the general position of the distributor should be that the vacuum advance line points between the 5th and 6th cylinder EXCEPT my `68 should point more directly towards the firewall. Well, if I'm at 12 degrees BTDC I'm pointing between 5 and 6 and I seem to run better adjusted a little more advanced than that. It would never run well pointing towards the firewall! Does this mean I don't truly have a `68 (my casting numbers on the block read 17 C8DE G015-B) or does it have something to do with the distributor that's in there. I'm not sure exactly what year they first started putting centrifugal weights in but I recall it was late 60s. Note: I just put in a rebuilt harmonic balancer in about 3 months ago so I'm pretty sure my timing marks are accurate and I've also checked that I'm firing to #1 when I'm at TDC of the compression stroke.
This all started when it began idling rough and would almost die at stoplights. New plugs and a good set of performance wires helped a lot. My plug gap is .038. Then I noticed a lot of oil leaking out of the top of my coil so I put in a new MSD Blaster 2. I had a Pertronix Flame Thrower in but wasn't impressed that it only lasted 3-1/2 years. The rotor and cap are 6 months old and look good. My old plugs were in OK shape considering they had been in for quite awhile. The ones in cylinders 4, 5, and 6 had a fair amount of dry black soot on them. I understand that means it could be running too rich. My compression numbers are (front to rear) 158-157-156-146-156-154. I have 19lbs. of vacuum at 700 rpm in park. Also, I have a Pertronix unit in place of the points.
Anyway, I'm at the learning stage with "engine fiddling" so I thought I'd see if anyone had any comments on my situation. It's running pretty good now but still runs a bit rough until it's good and warm. I only have a 10 minute drive to work with lots of stoplights so it doesn't get a really good chance to warm up in the chilly months.
Thanks...
Thanks...
