Full vacuum advance at idle is normal assuming you have the vacuum source connected to a manifold vacuum source. At idle is when you have maximum vacuum, therefore maximum advance. At idle, you have little to no centrifugal advance contributing to the total ignition advance. If the engine is pinging etc, then you might try to connect the vacuum advance to a ported vacuum source on the carb.
If the vacuum motor on the distributor has a straight nipple, it may be adjustable. Try sticking a small hex key wrench inside the nipple. There is often an adjustable screw that adjust the tension on the diaphram.
Typically a bigger bumpstick will allow you to run additional ignition advance (assuming the pistons and the stock compression ratio were not changed). The bigger bumpsticks usually have more overlap, which reduces dynamic compression ratio.
