Do any of the head bolts enter the water jacket?
LaGrasta
2K+
I thought my head was leaking water, but I realize the stains on the block start above the head gasket, on the exhaust side and the rear corner and front corner of the block, about where those head bolts are with the strange bolt heads. I did give each head bolt an extra turn and re sealed the valve gasket as it was leaking (as usual). I plan to give it a run tomorrow.
I used gasket maker in combination with the rubber valve cover gasket and it has to dry. I used way to much and am almost certain it dripped. I hope it works it's way to the oil pan succesfully.
