... you mention the (
carb'd) "early Turbo Buick setups", I'm working on adapting the early Buick setup rather than build a system integrating unknown components. The
draw-thru setup first of all requires a specialized turbo built for
fuel-thru and the Carburetor operates non-linearly unlike a blow-thru carb needing it specialized for draw-thru turbo use. You may hear there are no good draw-thru carb'd turbo setups and only fuel injection will make it actually workable. Secondly - Ignition timing vs boost is a considerable concern which now can be made workable with MSD type boost-referenced black boxes or more home brewed solutions.
... here's a page from MaCinnes' book , although dated it describes a Ford 250 draw thru setup using a Rajay turbo and Weber DCOE45 setup, if you can believe the dyno figures it claims to improve the 4000 RPM RWHP figure from the stock 88HP to 191HP...
> my current project D7DE 250 cid mostly stock with 1980's Buick V6 TBO3 turbo, very specifically built Quadrajet and head re-worked but OEM 62cc chambers retained for running SCR @ 7.83:1 . Runs good static on test stand and currently working on ignition timing/boost controls (
home brewed) before road tests.
Blow-thru vs Draw thru each has distinct challenges but if you are ambitious enough to attempt to build a turbo setup, members can help with the specifics... There are a few blow-thru setups among the members and experienced and road tested info is available. With the advice from members and what I've learned, I'm also working on an alternate blow-through setup and building a blow-thru capable Holley 2300 2Bbl to use.
have fun 8) .
