Sorry. I haven't got may digital camera handy. The early Weber is a left handers, the later 5200 is a right hander, depending on how yopu look at it.
Early American Pintos had the Autolite built Weber DGV with water choke. It had the choke on one particlar side.
The European Cortina had the choke on the other side.
32/36 DGV (Manual Choke)
32/36 DGEV (Electric Choke)
32/36 DGAV (Water Choke)
32/36 DGFV (Electric Choke, reversed side)
Then Holley made it the 5200 series, branded as there own Holley, not with an Autolite part number. The Vega used a similar version, but with the primary and secondary reversed.
From the back, most of the American carbs had the choke pointing to the centre of the engine.
From the back of this Holley Weber 5200 carb of a 2300, the choke is reversed and the linkage is slightly different
Asside from some odd mirror imaging, the return line on 'foreign' Fords and the possibility that the secondary and primary barrels could be the other way around, they all bolt up to the Stovebolt or Clifford adaptors.
Hmm, if you used two, and had one carb from a New Zealand Cortina, and one from an American Pinto, you could run one electric choke and mount them like Albert Penello's, but doubled up.
If you want one, just holler!
