Just so you know, I have all three types of headers (on my website) in stock.
From what I have learned, most sixes (stock or mild build) will actually benefit by using a single pipe rather than duals. The exception to this would be a well built six with big cam, larger valves, increase carburation, head work, etc.
Falcon62 is correct. Dual out pipes should be from 1 3/4 -2 inches, but no larger. I would recommend 1 3/4 for a stock or mild build. Single outs should be 2 - 2 1/4 inches.
If you like the looks of a dual out, but prefer a single, then run the pipe back to a mufler with a single in and dual outs. Then you have the best of all worlds. Cheaper, easier, good sound, good performance.
If you go with the Pacemakers and a Y pipe, you can always convert to dual out when required and/or when you have more cash.
