I watched your video, and it looks mostly "normal" for idle vacuum advance timing (±10° vac advance at ±12"Hg), but two things jump-out that are worth looking into before too many assumptions are made. First is only 12"Hg at idle.
Idle vacuum should be more than that, for a stock-ish engine of this type. Second, revving will see vacuum drop like a rock initially, but should recover to high vac holding higher rpm. Yours does not appear to.
One approach to checking this is to disconnect the vacuum canister, and repeat the exercise, re-setting idle rpm and do your revving as before. If the engine has greater idle vac, and vac recovers well during light rev-and-hold - you have a vac canister issue. If the symptoms are relatively maintained (continuing low vac at idle and poor vac recovery after initial throttle), then you have a mechanical advance, carb tuning, exhaust, or timing mark issue.
As you (and we) have no idea what Cardone did to it before you got it, we can side-step the possible mechanical issues by setting the timing at max advance, instead of curb idle advance. Max advance is a known and controllable value, of perhaps 36° all-in. If we rev (no vac) to the point all advance is in, and set timing to 36°, then we can let it idle-down and see what Cardone did with the timing curve.
This
importantly maintains high-speed and high-load timing for engine safety, and the remainder of the timing curve - no matter what the less-dangerous low-load is doing.
I'm not trying to make work for you, but the issue needs solving in any case, and this is one way to approach it without added expense. Note that engine idle timing was historically always very advanced (maximum brake torque timing) until (mostly) emissions pushed the factories to ported vac. It should be capable of great operation on manifold
or ported vac, if everything else is as it should be.
Even today, many engines that are not under emissions requirements use manifold vacuum for advance, for efficient and effective timing control. That's a nice way of saying that those claiming
only manifold or
only ported vac is OK, are misinformed.
They are two different approaches for different reasons and goals. While your new distributor was originally set-up for ported vac, it can run well either way, when set-up and operating properly. Your SCV/LOM carb is currently forcing you to only manifold vac, but either the distributor or the carb can be modified for good function, and both will need some tuning. Which path do you wish to travel?
Below is an example vacuum advance chart for a generic adjustable vacuum canister (many curves and ranges available), to show some of the effects available at 12"Hg idle vacuum. With a typical Ford I6 10-20° max vacuum advance, most of it would be applied at 12"Hg. Not sure where the Cardone tech got 5°, but then again, we don't know how it was set-up by them.
