Going to step up to a DSII this weekend (after having found out that I'm running a L-O-M dizzy with a Holley 1940 that has no SCV... *sigh*).
I want to do the recurve procedure set out in the "Dramatically Better MPG" sticky. Lots of good info in that sticky... but it is manifestly unclear which spring is the "lighter" spring. Here's my DSII:
When I rotate the reluctor plate, the spring on the right is already fully engaged (i.e. no slack). The spring on the left has some slack and it does not "catch" until the plate has moved a little more than halfway along the 13R slot. For clarity, I'm going to call the spring on the right the "primary" spring since it is engaged for the entire travel of the plate. The other spring, that engages later, I'm going to call the "secondary" spring. (Someone please correct me if this wrong.)
The $64M question: Which spring is the "lighter" spring?
