Duraspark spark plug wires OEM number
Argie Falcon
People, I need help with some numbers.
I need to know the OEM or casting number of a set of spark plug wires for Duraspark system, for a 200" engine.
Thanks for your answer,
Mariano
See if you can cross Champion #69411 Or Belden #700229, Those are both listed for Ford. You could also try Champion #69420, that is listed as a premium universal set that you cut to length and crimp on the distributor and coil ends. Any Ford or GM inline 6 from mid to late 70's will have the right ends. I usually use 78 because its a few years into the electronic spark systems and just before the computers. The length seems to vary even in the 'exact fit' sets, thats why if looks are important the cut to length are good. A GM inline 6 would also get you pretty close, the only difference would be the GM ones have a little nub on the coil end that fit into a retainer ring that locked down on the top of the cap.
